Hi all, Gotta take tank out & can't find drain, also where is the connection for the fuel line, I think I see the gauge wire on top of tank. Any tricks in removing it? Also where can I purchase one? Thanks
Wilwood Engineering1955-1957
Not all manufacturers fitted a drain so you may not find 1, as for the fuel line connection maybe accessible through a small plate screwed to the floor of the trunk which most likely be where the guage wire connects as well.
There is no drain plug, you will have to pump out the fuel. Check Rockauto online for a replacement tank. Dont try to remove the tank with fuel in it.
