Hawkeye Offline OP
Can someone tell me how the wire for the gas tank sending unit is routed? Does the wire run inside the car or outside? If inside, where does the wire exit so it can connect to the sending unit itself? Thanks
My semi-educated guess is that it is under the load floor.
Hawkeye Offline OP
Thanks Gene.
