#45058 04/27/04 08:29 PM
I purchased a partially restored 1940 1/2 ton P/U. It has an 8 volt battery. The previous owner said it is fine to run with it. He mentioned some type of adjustment he made to the electical system so it would be compatable.
Does anyone know what he was talking about?
Thanks to all that reply.
mark
#45059 04/27/04 08:46 PM
I have used an 8 volt in the past but don't remember running any type resistor (?) if you have to go to that trouble then why not go 12 volt?? I'm sure someone with recent experience can help more and maybe help me remember??
CHEVY: TAKES YOU AND BRINGS YOU BACK
#45060 04/28/04 12:53 AM
The adjustment was probably to the voltage regulator, which uses the system emf (volts) to control the generator charging current in amperes. With an 8 volt battery in the circuit a regulator that is set for only 6.8 volts would see a more than fully charged battery and would reduce the charging current.
If you have old Chevrolets, other old Chevrolets will find out where you live.
